anybody know how much the stock rear seats in an S14 (kouki if it makes any difference) weigh? are they easy to remove? to anyone who’s done it - is it worth it?
it’s a daily driver (no need for the back seats), however i’m slowwwwwly trying to make it more track-ready…
the wieght is like 20lbs its ALL FOAM almost except the backing has a thin sheet of metal. in taking it off. the car gets alot noisier if ur daily driving it. its like noise reduction.
ps: i only have 1 windshield wiper at the moment, and WOW what a difference in acceleration! i can take turns at twice the speed, and even civics dont mess with me anymore…best mod EVER
tbh, if you really want to save weight take out your ABS actuator, just pulling the fuse will get rid of ABS but the actuator is alot of weight. And you cant just thinking weight reduction, think about balance, many s13 owners move the battery to the back or run a slim battery. I’ve stripped my s13 in the back, and i’m working on HICAS and ABS delete this spring once i’ve gotten all my parts, that should be quite the difference.
Hey there, I pulled my back seats to put the cage in and for weight originally. I then put it all back because it really helped with the sound resonation. Its not worth saving the weight unless its a pure race machine. Besides its foam wrapped in leather or cloth…doesnt weigh much!
white2abbit weight saving is a very costly endeavor. anthing that will show you a difference in performance is expensive. what ur aiming to accomplish in weight reduction in any car that ur going to track is rotating mass, so here are some things you want to lighten ( flywheel,driveshaft,wheels and even tires) try to remember you already added weight to the car with bigger exhaust, intercooler,piping etc so you would need to remove alot of things not just seats to see a difference.
