rattling noise
yeah, my dad’s max got into a hit and run
it’s fixed now, the driver side’s fender was replaced
now it rattles when it goes 90+ km/h
any idea where it’s ocmming from?
thanks
Yeah where it’s ratteling from…
If it’s the fender rattling, maybe one of the bolts were not totally tightened or is missing. Check under hood and inside driver’s door crack.
Good luck.
yeah I wish I knew… if only I can get on my rollerblades, hold on to the car, and get my brother to drive ther car to 90 km/h.
thanks darkforce, I’ll be doing that tmr
Could be an out of balance wheel causing vibration then rattling. Did you guys check out the suspension assembly? There could something bent causing noise.
Also, double-check to ensure your strut tower bolts are tight as well. They’d probably give you more of a “clunking” sound on bumps etc…but still…check 'em.
