so i gots this AWD skyline with an RB20det I want to swap into my 240sx SOHC. What happens the the front wheel drive components of the AWD system when its in the s13??
you use an rb20 or 25 transmission, rwd only
I know with a RB26 swap into the 240, when switching to a RB25 transmission, the oil pan needs to be changed as well. Now, I don’t know if this is the case for the AWD RB20, but its worth taking a look into. I’m guessing if this is needed all you need is a RWD RB20 oil pan.
hmm. ya cause some people are telling me that the blocks are different on the AWD rb;s and the rwd
Nissan would not produce different blocks just to make it awd. That would cost to much
there is the oil pan on an awd car has a diff in it so just find a stock rb20 or 25 oil pan
oh wow thanks that makes sense thanks
