RB20DET Advice and what to do's
good shit, ya i got a rb20det turbo a rb25det turbo 2 down pipes and a bov
I know I am forgetting a few little things but those were the main parts
SO has anyone tried or heard any news on the tophat motor mounts?
need to know asap as I have contacted them and they offered me free shipping.
No experience with 'em, sorry.
Hockey pucks work. No joke.
Ya but hockey pucks wont allow me to directly bolt an RB20DET in my 240sx…
Also looking for non nissan part number for a few things.
Timing Belt - Gates Racing if Possible (blue belt)
Timing Belt Tensioner
Timing Belt Idler Pulley
Water Pump
Oil Pump
Also looking for a good tuned plug and play ecu…
Whats wrong with OEM parts? =/
Try, Enjukuracing.com, Rawperformance.com, phase2motortrend.com. All sell rb parts. oh if you want OEM either the dealership or nissanparts.cc
There is a thread simply entitled RB. It has every answer to all your questions.
Oil pump? I wouldn’t even bother. Unless you have the monies laying around. Put a stock pump. N1 will push to much pressure at high RPM’s.
The collar issue seems to not be a major concern for the 20’s.
The main problems with the 20’s are the cam caps. The bolts seize inside causing them to crack. Or if you ever go to play with your cams, you break tons of bolts.
The head gasket is good for easily 300hp like Mike said. If your gonna go ML or MHG. Get Tomei. Do NOT settle for less.
The R32 cross member works fine. Just adjust it accordingly to clear the hood, steering shaft and fire wall (bell housing is tight)
The mounts make the motor sit WAY to low in my opinion. With the R32 cross member a stock sway bar works fine. As soon as you upgrade you have to make clearance on the sway/oil pan. With the mount kit, if your car is uber low. stock oil pans.
What else can I say?
