I need my rear subframe changed, i ave a replacement 1 and all the parts neccesary for the swap, im willing to pay someone to change it for me, im only doing this as i want the job done right, so if someone owns a shop or works at 1 and needs a side job this is for you, so let me knw if anyone is willing to do this, just pm me your details and a rough price, thanks Sunjay
Hey sunjay its not that hard u just need to be carfule about breaking bolts expecially the subframe studs.
Soak all the studs in wd40 for a couple days, then take the brake lines off the E brake lines off. Jack the subframe up take all the subframe bolts out and vlsd bolt. My subframe didnt fall out, i actually had to jump on it. Its very easy, u can have it done in a day two max, just getting it in sucks u have very little room to play with
=( im doing my rear sub frame swap on friday after i pick it up, not looking to forward to doing it =( I just dont wanna mess things up and do it incorrectly =(
the only main concern i think would be breaking bolts. wd40. jiffylooo or what ever you have to do for a long time before. My friend works at nissan and even some of hte 2002’s break subframe bolts.
i broke a subframe bolt on mine. It was a bitch to replace. Luckily darian cut me out a subframe bolt from one of his parts cars. I pressed it out then cut a hole in the floor where the bolt is(there are markings) and i grinded the head off of the bolt drilled into it and finally it snapped and came out. These things are ridiculasly strong probably like grade 10 bolts. Its hard to even grind into them they are so strong!
So dont break them its a piss off to replace!!!
Sunjay I PM’d you with a quote, if you decide not to do it yourself let us know
if Sasha does it you wont have to worry about broken bolts and things going wrong
a small price to pay for a decent sized back yard job and peace of mind
if u get the car towed after i pull everything off u guys can do what you want with it.
still alive tho? Lol
