Recommendations for brake replacement
So my rotors are warped, calipers are seized.
I’m looking suggestions for brake replacement. I’ve been reading a lot as I don’t have a mechanical background. From what I figure, I’ll need to replace my rotors and calipers. Of course, if I choose to go beyond stock rotors, pads and calipers, I’ll also need other hardware to accomodate the upgrade.
What other hardware would I need?
Are there full kits available?
Thanks,
what are your plans for the car and how much money do you want to spend?
180sx brakes are bolt on
q45 are bolt on if your 5 lug
300zx are bolt on
lots of options
taurus brakes
Ah sorry bout that
I’m not going FI with this car. It is a daily driver. I do have basic bolt-ons, but I don’t intend on going much further with it. I have suspension mods, also very minor (shock+spring+bars).
I suppose I am looking for OEM replacement, or just better than stock. I suspect that I don’t need a HUGE upgrade as I will not be producing much power (relative term? :slight_smile: with this vehicle.
180sx brakes will be really good for you. Are you 5 bolt or 4 bolt though? If you’re 5 bolt, go with Q45 brakes, direct bolt on. They will be more than enough for your needs.
