OK so this is a 2 part question:
Im finally got my clip-ons, switches and grips in the mail for my GS1000 cafe but now Im looking to replace the clutch lever and the front master cylinder. I will be running GS1k spokies but Im unsure about my brake setup. Is it possible to keep the dual disks in the front when using the spokies or do I have to go down to one?
When replacing the master cylinder, what do I need to look for to make sure that it will work with my brake setup? I want to run something like this:
or like this:
The cleaner looking the better
My plan is to retrofit a gravity feed oil reservoir from industrial machinery to act as the reservoir and make it unique. This is the reservoir I have in mind for the front:
Im not worried so much about retrofitting the reservoir, more so making sure I get the right master cylinder “unit(?)” and then tackling the retrofit after I get the original piece to work. I dont understand what the specs mean when i look at aftermarket units and Im not sure which ones can be used from other bikes. I would like to keep everything metal of some sorts since everything else on the bars is going to be metal and plastic free.
So, anyone have any advice or information?
