Replacing Motor/trans mounts on a 3400SFI
Mhmmm.
3400.
motor mounts.
headache.
I replaced the Front motor mount (Some people call it the upper I guess)
I replaced the Rear transmission mount (Some people call it the side transmission mount, driver side)
Howeverrrr.
The fucking left/right transmission mounts (some people call them front/back) are giving me the biggest fucking headache.
I’m sure someone is familiar with changing them, anyone have tips?
It’s specially a 99 grand am.
Same mounts/frame as alero, etc…
I probably should have just taken it somewhere to replace them… as that would have been easier. Ugh.
Soooo anyone want to come by and do them for me? :stuck_out_tongue:
Money money money! ;D
I have more than enough tools for the job, it’s up on ramps + blocks now.
No lift, sorry.
Tips, or come and do it.
halp!
What exactly are you having trouble with? I swapped the mounts on a 3400 before and didn’t have a single problem.
On how to exactly remove the Left/right transmission mounts.
They look like this.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Transmission-Mount-Anchor_15300065-P_38_R|GRPENGPAMS_729221436___
Does that come out by itself?
Or does it come out with the entire metal mounting bracket?
I’m 95% sure I’m making it out to be way more complicated than it is.
But I can’t for the life of me figure it out.
I have managed to remove the bolts that go in the rubber mounts themselves, but the mounts won’t come free.
So I assume there’s more that I have to remove, although seems rather tricky -.-
Or maybe I just have to raise up the trans/motor more to free them up… I don’t know.
Meh.
Front one was a little messed up.
Pics of front;
Rear just had a couple small cracks starting on it.
not as bad as the front.
ew, double posted.
meant to edit not quote :S
here’s a video of what the movement looked like.
