Running 8 ohm speakers on a 4 ohm amp?
Ive got two 8 ohm JL Audio subs rated at 125 watts rms each, and a Volfenhag ZX-7180, which is rated at between 300-400 watts rms per channel into 4 ohms (depending on which website i go to). can i run this amp into these speakers at 8 ohms (theoretically halving the power to the subs) and not do any damage to the amp?
you won’t damage the amp, but the amp will only out out about 1/2 the rated power to the speakers.
Nope, will not damage the amp. I would bridge them and run it 4ohm that way if I were you though.
[quote=“01AudiS4,post:3,topic:27010"”]
[/quote]
but this may damage the amp; some amps can’t handle 2 ohms per channel…
[quote=“97FormulaWS-6,post:4,topic:27010"”]
[/quote]
2 8 ohm subs wired in parallel will bring you a 4 ohm load. bridge the amp if a 2 ch and bam, u will have the proper ohm load for your subs and amp
[quote=“dreid,post:5,topic:27010"”]
[/quote]
If you do this (Wire the speakers in parallel = 4 ohms & Bridge the channels); the channels split the impedance; thus each channel only sees 2 ohms. Some amps can not handle 2 ohms per channel.
well, as long as i wont damage the amp, im going to wire them as two 8 ohm speakers. if i bridged the amp, and ran them as one 4 ohm speaker, they’d each be getting more than twice the power they are rated for, and im going for SQ, not SPL.
Thanks for all the responses!
[quote=“97FormulaWS-6,post:6,topic:27010"”]
[/quote]
yes but the amp can handle the 2 ohm load per channel
how about this?
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=2
[quote=“KuntryQuestTSi,post:9,topic:27010"”]
how about this?
[/quote]
That was suggested above, and I’d do it if i had an amp that put out around 300 watts rms into 4 ohms, but mine does much more than that (bridged) and I dont want to damage my subs. thanks, though.
Moved to the correct forum. Don’t make a habit of this.
well 8ohm is pretty high and seeing they are only SVC subs your limited to what you can do…
