anyone know of a good place to go too get my quarter panels welded up. thanks
if you are replacing quaters there are other ways to go about doing it than welding. the most common way i have seen is using a 2 part adhesive process. much easier and in my opinion better, there is NO warping or burn through on the metal. which makes for a much more accurate panel replacement.
post more info and maybe i can help.
accident? rust fix? flares? old or new panels?
I use to do that back in the day when i had rusty cars.
Worked real well and never had problems. I guess it depends on how high up you want to go on the quarters.
epoxy shit cracks eventually and also isn’t perfectly flush obviously. welding is the only way to go. xpert paint on kenmore and starin will do it inexpensively, they just take fuckin foreeeever. like a month minimal. but he’s cheap and it comes out well.
:fry: Good luck bro
buy a welder and angle grinder. Grab tin snips an go to town
Along with some Finberglass filler :tup:
Wayne Ill go halves with you on shit if you diy, ive got a tiny bit on the hatch thats bothering me.
