hey i decided to take my rear mudflaps off…and turns out they are prime area to hold water/salt and the rear quarts are rusted to $hit …should i change or body fill…here let me get some pics
drivers side
passenger side
now anyone wanna tell me the best way to fix this? body shop? or changing the whole thing…and please i dont wanna hear…cars a rustbucket get rid of it…
If those are the only rotted parts on the quarters then just get that area replaced from the body line down. My opinion is if you want it fixed right and have it last get a good body shop to repair it with new metal and not just fill it with bondo. You will need to replace the inner quarter aswell where its rotted too so this is quite a job and more rust might pop up when you actaully start doing the work.
if the upper part of the quarter panel is fine like around the wheel well etc then dont put in a new quarter panel
this is an easy fix, all u need to do it cut out the rust. once thats done get some metal and weld it on, try to keep the cut of the metal nice and simple for example cut it in a rectangle shape when u cut the rust…then after that use some body filler to fix up any imperfections and personally i would invest in a rear skirt oem or aftermarket and it would cover up some of the job, incase ur not the best at body work
easy fix
but if its rust around the wheel well then replace the whole quarter
