Now, I am in need of a drive shaft in VERY good shape. U-joints must be amazing as well as the rubber insulator by the output shaft at the transmission.
PM or reply here please.
for abs and non abs the only difference is the front 12inch section,
so you could buy either abs or non abs and swap your front section on.
i have one you can have for free ill just have to check if the carrier bearing is any good
let me know if your interested and ill check
definetley interested.
abs or non?
k hold on ill check give me 10 mins
no rush dude. i can pick it up weds or any day after thats good for you.
damn i forgot the carrier bearing is on the front section
ok so i have 1 looks to be in good shape but i have no fucking clue if its abs or non abs
ive had a bunch of these things lying around and i can remember what its out of
measure the front section of you drive shaft and i can tell you .
abs is 1 inch shorter i think
18 1/2" front section from the end of the sleeve on the shaft side that goes into the transmission the the end of the first u-joint
I don;t know where your measuring yours from how ever. (mine is in my car)
lol k hold on, i think i may of made a mistake mabie all the fronts are the same and the rear sections are different
im going to bring it inside
lol alright brother. i appreciate it a lot
16.5 inch from the dust cap that meets the trans - the start of the first u joint
so im guessing the u joint is 2 inch. i think i was right the second time there all the same in the front section because i think this is a non abs shaft
The rear half of the shaft is what is different. The front’s are always the same due to hangar bearing location.
Rear - 26 1/2"
Front - 16 1/4" (installed on car, do not account for any of the splined part)
Overall - 43"
come grab it tomorrow if you want ill bring it to my shop in concord
so its closer to brampton for u
okay so 16.5"
I’m leaving work now, so i’ll talk to you tomorrow.
I appreciate your time bro. Thanks again, very much.
tomorrow is a no go. tuesdays is wife night lol.
weds is good for me. pm me your address and a time after 6:30pm
or wed if u want
NP
