S13 Motor swap details...
yes i did search, but did not come up with what i wanted to know…
so when doing a motor swap(sr20) in an s13 what details are often overlooked? misc things i figured you would repair/replace while the ka is out…
-fix some rusty hard to access sections
-new motor/trans mounts
-new fuel or brake lines
what else should be done? or would you do?
Clutch and good fluids
diff flush
Clean and paint engine bay
change seals in the motor. mainly the rear main and oil pan seal.
cleaning the engine pay and motor go a long way to making your car look that much more baller…depending on what kind of abuse your planning on giving the car you could stich weld the seams…
I believe you are looking to change the fluid, as you cant flush a diff. A flush intercepts a system fluid circulates (not saying a diff doesn’t, but read on) and uses the pressure of the system to exchange the depleted/contaminated fluid with fresh fluid. Good examples of a flushable systems would be transmission (auto), or cooling system. Anyways, you are on the right track with addressing all the rust and the hard to get to areas while the motor’s out. It’d be a good time to check out brake lines, steering rack, etc. DEFINETLY give that engine bay a firm once over seeing as it’s empty,…make it clean, because emptiness is loneliness, and loneliness is cleanliness, and cleanliness is godliness, and god is empty just like…Billy Corgan,
if u have that gay box on ur clutch line system, this would be a good time to remove it.
i highly recommend picking up a steering column bushing and replacing that while the motor is out. and by steering column bushing i mean pick up a solid aluminum one (bing usually sells these).
best ~$20 you’ll ever spend on your car.
also make sure to go over your heater core lines too, making sure all the rubber is still pretty fresh (check for cracks).
my s13 is pretty raddy right now… so i dunno how much $$$ to dump in, i was only planning on keeping it for another year or so till i buy a kouki, who does brake/fuel lines? how much does it usually cost? ive done it on sterndrives but that shit is dumbass easy…
also, what parts are interchangable between s13 and s14(try not to waste money and only buy transferable upgrades)
avery was tellin me to do that too… whats it for anyway?
It’s supposed to dampen the vibrations sent from the slave to your foot…and it’s a BITCH to bleed. I dropped mine out of my first 240, didn’t really notice a difference.
