S13 with rear Z32 Calipers
I once heard that using the z32 rear brakes and staying with a 4 bolt pattern on the s13 could be done. Does anyone know what rotors I can use that has the same overall diameter, thickness, and hub size to stay using 4 bolt hubs? I am thinking that it was mentioned that mitsubishi eclipse or subaru was the same. I cant remember. What about altima’s or maxima? I also thaught of the J20 and J30 infinity. Can some one help me out please. Thanks in advance.
you can z32 rotors just have them redril for the 4lug, iirc
I prefer not to use the z32 and redrill. I want it to be 100% hubsentric and I also don’t want to have to re ballance everything. I would like to buy. Thanks though. I already knew that option but forgot to write up the preferal. My appologies.
z31 non turbo 84-86 4 lug 11" rear rotors
yeah, I had mine done by a CnC tooldie maker, 5 lug to 8 hole.
there is no balance issue
mind you this is better than the use your old rotor as a template…
