I searched and still couldn’t find a solution to my problem but my dash lights are not working (cluster and hvac controls). They were working when I purchased the car, but after I installed the radio I might have shorted something and the lights ceased to work afterwards. I checked fuses, even the tail lamp fuses and everything checks out fine. Might do a triple check tonight. Did some research and read that I might have shorted the dimmer switch, so I bypassed that. I bypassed it by grounding the red & yellow wire, hopefully that is the correct procedure but still no lights
even took the cluster out to see if the bulbs burnt out and replaced them and still no luck. Read something about the TCU but apparently that only applies to S13’s.
I hate driving at night with no dash lights, although i’ve been managing essentially it’s a safety issue.
So if anyone has any suggestions as to what I should do or check next, it would be greatly appreciated.
Thanks in advance.
Oh and to be more specific, with the cluster the seat belt light, gas light and signal/high beam, etc… all work, it’s just the back lighting that doesn’t.
