S14 Wheel spacers help! Flushness wanted!
k so i just picked up a new set of rims… and i want them to look flush.
so what size spacer should i go with?:/:
Front: 17x8 +35 with 215/45/17s
Rear: 17x9 +38 with 235/40/17s
Spacer size?
Mount them and see you jackass.
Or get wheels with better offsets.
If you’re running stock alignment, dropping the car will result in some negative camber. the lower you go the more negative camber you will have. If you want them flush you have to mount them and see how flush they sit then decide on spacer size. If you’re running adjustable multilink and coilovers or aftermarket knuckles you can adjust camber and run a larger or smaller spacer relative to how your suspension is set up.
considering 17x9.5 +15 is flush on stock body search mb battle pictures on s14. thats close to x9 +10 or x8 +0 … so u do the math of what spacers u want
k thanks! lol
btw not looking to buy wheels. already did.
ill was thinking 15mm & 20mm
taht would make it like…
+20
+18??
right…
um i have sportlines for now, soon coilovers, but stock multilink.
Keep in mind if you go more then 3mm spacers, you’ll need longer wheel studs.
unless they’re bolt on… in which case… dooo ittt!
i was thinking nismo extended ones…
20 front 20 rear will look nice.
also thinking taht!^^ wasnt someone selling them?
sell the wheels and buy some coils + multilink.
Save yourself the humility of riding in a stock body with sunken wheels, 4x4 ride height and lots and lots of body roll.
man, ppl should rlly read previous posts…
Go for 20mm spacers in the front and 25mm in the back.
I would HIGHLY suggest using bolt-on spacers since you’re using such large ones.
I’ve done 30mm spacers, tracked and daily’ed no problem.
even if i got nismo extended ones, would i need bolt ons?
no… but bolt on spacers ftw! i tracked on 25mm bolt on spacers and it was fine… also it’s easier to sell bolt on spacers after… oppose to slip on spacers with extended studs…
makes sense…
and wtf u have spacers? i thought u just had natural mad flush. lol
i have spacers for my 17x9.5 +15 for track… effectively x9.5 -10… wooord
