setting up a hydraulic clutch?
ok i was told that the source of my slippy clutch could be from it not dis-engaging properly and that i would have to set this bolt up properly so my clutch pedal comes out all the way,its a 14mm bolt with a 14mm nut on it and u can make it so the pedal itself is closer or farther from the floor i took this bolt and nut completly out so my clutch is all the way out, but what i wanna know is could it work in a reverse fashion so if my clutch pedal is to far out would it engage,and where should it be set to?
depends on how it was set in the firsy place. Im sure you could fiigure somthing out by taking a look at the adjustment on the peddle. Im doin ghte same thing. But it will not make the clutch less mushy. It will just make the clutch engauge and diss engauge at a diffrent point.
