So I recently installed the sportster 5 kit in my 01 jetta. I am using it through 88.1fm. I have noticed that I get signifant feedback while driving around and it doesn’t sound good at all, like im getting other peoples stations. I assume this is because were all set to 88.1
I have the antenna mounted on the trunk. Can you guys reccomend anything to improve the feedback it’s not very clear.
I’m posting here to give a false sense that maybe, just maybe, someone had an answer to your question.
Here’s to hoping you have a subscription with instant email notification to this thread, so you can get all excited and expect a decent answer as you’re reading this.
Ryan why did you even make a thread for this if you knew Jim was going to have the answer…he always has the answer for car audio and you have his number dumbass lol
I have the same unit. I use 89.5 and the system also comes with an FM out antenna. Mount that to the window as close to your vehicle antenna as possible. That should get rid of your feedback noise.
Thats the point of the direct connect adapter, it plugs in-line with your vehicles antenna and uses a relay to break the input from your vehicles antenna when the sirius tuner is on.
im just not a fan of using those things. i prefer an aftermarket deck with an aux plug in it. plus they end up sounding cleaner than oem stuff most of the time. Jim’s suggestion totally works, dont get me wrong, but its like the cheap way out, or temporary if youre waiting on a new headunit to come in. most of you here dont give two shits about SQ, so something like that setup will surfice, i need an actual cable with a plug.
if The sportster is recent , it should have come with a second antenna… a real thin gauge wire with a sticky section on the end. I couldnt get shit in my Chevy pick up , until i removed the 2nd antenna… With my Ford, I have to use the 2nd antenna. I have 5 preset stations, and use most of them depending where I am locally, due to feedback…
Sirius and XM quality sucks cock anyway, it’s a waste to buy a deck and sat tuner for ~$300 when you can just buy the cheapest siruis tuner and an FM mod for $60
