I have my Sirius Sportster 5 hooked up to my car (02 Jetta) via wireless fm modulator antenna and plugged into the Cigarette lighter. The volume is all the way up on the Sportster unit, and it is still not very loud coming through the car speakers even with the volume on max on my stock headunit. If I play a CD, the audio sounds great, loud etc.
What are my options here? The stock deck doesn’t have an aux port for direct connection. Replacing the stock double DIN deck with an aftermarket deck doesn’t appear to be too simple. (Appears to be wire harness issues with these Jettas).
I also don’t think I have the Monsoon system if that makes any difference.
wired fm modulators don’t need aux imports, they wire in through the antenna port, but u will need 2 antenna adaptors that i might still have sitting around my house so i could give a look for you. what year is the jetta?
The ones i used to use for overhead DVD systems used a box that the foctory antenna plugged into and then that box plugged into the factory antenna location
Just plug your source into the FM-MOD02’s auxiliary input or RCA inputs, then tune your FM radio to the selected frequency.
I could be dumb, but isn’t this what I’m doing now.
I still don’t follow how plugging it in directly would allow the volume to be louder.
So, with this and the wired FM modulator, I’m at almost $100 bucks to get better audio sound. Wonder if I should just put the JVC deck in I have and run it off Aux…
Currently just the bolded, I do have the wired modulator sitting at my house waiting to install. I apparently need some special connector for the antenna though.
