So which nissan powered E30 will run first
Newman’s or…
http://forums.bimmerforums.com/forum/showthread.php?t=1106773
Newmans will be way more baller. But that one will probably run first lol.
EDIT: Boooo, SR20.
Sr20 are so last year
mmm … widebody
i’ll post a link to newmans there hehehe
if you like nissan engines, you should try to fit and RB TT in there
someone actually posted that on that thread
the guys response was great though
[quote="KarlSpackler
I actually care about how much my car weighs
[/quote]
mmmmmm e30 m3
ughh, what a waste. If your gunna go through the trouble of swapping something non bmw in there at least make it worth the time.
+1
RB >
lol… on paper you suggestions are correct… on paper.
yeah like an LSx :wink:
GT28R 300rwhp SR20DET E30 M3 Proj3ct
:gay:
GT42R / BW S372R 700+ whp M3
:tup:
you guys are hilarious.
sr20 is a great motor.
RB swap is way more more difficult.
I’m with the owner of the car on this one. He actually likes to turn his car, anything larger would be unnecessary for his desires. This motor is replacing what was a 4 cyl with another. It will keep the balance of the car spot on and give him a power advantage. For what he wants out of it I believe he made the best choice.
rb doesn’t weigh much more then a sr20 even still 90% of bmws are built around the weight balance of a i6 motor
That thing looks like it will be quite fantastic when all is said and done.
you cant be serious right? an rb w/ tranny weighs almost 800, an sr is an all aluminum block & head, and the transmissions are about half the size.
i personally would go rb, they are deff worth it, the power band is wayyyy different than a sr.
not when it comes with an I4…:banghead:
i would see it being about the same into any thing that is not a nissan, and even into a nissan, its not that much more difficult
200-250lbs difference somewhere in there. which is a considerable amount.
the sr having an aluminum block doesnt have that much to do with it tho. the ca18, also a nissan 4cyl with an iron block weighs less.
