Was at the ATTS at the DDT and after 3-4 laps my brakes started to go and smoke coming from both front wheels! I have HP+ all around with stock S13 brake and DOT5 fluid! Besides going 5 lug with bigger brakes, will braided lines and slotted rotors help much? Anything forsale?
Pur auto carries Motul, and have tons of rbf600 in stock.
If you want to get ambitious, you can always make brake ducts. On top of the previously mentioned items you should be prettty content with your braking.
I’m only at 228 at the wheels and weigh in at about 2600lbs. I was only 2.2 seconds off FTD against some pretty fast drivers and cars and that was my first time on that track and first time on a track with my car which was primarily built for Autoslalom. The brake fade really made me brake much ealier then needed!
I’ve ordered some Blues and new front calipers, braided lines and the RBF600…that should solve the problem I hope!
Thanks for the help again Adam! I’ll see you at a Solosprint event soon!
I sometimes bring my 911 to DDT and its my daily driver, I can fade out the Hp+ in about 4 laps…
the hawke blues will be a good choice…they are very hard to fade out in a 240sx unless you are high power …and really have to haul the car down from speed…only downside is brake dust from them…
the HT-10’s will not fade out…at least I have never been able to fade a set out…even with 450rwhp in my turbo 240sx…and 305hp in my ls1 240sx…
however… THEY MUST BE BROUGHT UP TO TEMP…they would be dangerous on the street…cause you would never have enough heat in them to work…
I would forget slotted rotors and just run brembo blanks…never had much luck with slotted or groved rotors…the standard blanks are great…
