I removed the alarm from the car, and not it sounds as if there a miss, idles but very bad, I pulled couple plugs blacker then ever, checked the wires, nothing wrong there, freak thing was ran perfect 10 min before I removed the alarm, checked to see if any wire ie, tach or ignition coil wires where grounding out and nothing. Checked all the fuses. Any suggestion.
was it a remote start or alarm?
alarm no remote start, all I did to remove was cut the leads that where coming from the alarm control box all the way up to where they were spliced into my stock system, I made sure to carfully trace the wire before I cut the wire that it indeed was from the control box. now it seems that I have a miss in the motor right after I did this.
