Okay, so I’m replacing the speakers and I’m having a hard time trying to get something in there to loosen the screws. It’s a S13 F/B by the way. I have a set of stubbies, but the space is even smaller than that. What did you guys use? Tks.
Okay, I can get the speakers out. What do I do with the OEM connector though? It’s that black plastic piece that fits nicely onto the old speakers. The new one’s have the two connectors spaced out. Do I break the connector and use the two wires individually? Also, do I have to put anything over the connections? Newb questions probably, but I haven’t done anything stereo-related before.
If you are talking about the stock speaker amp… either by-pass it or remove it. If you use it with a new deck and speakers it will sound like crap.
You could just wire the speaker up to the positive and negative wires coming through the door harness.
My deck is old, not factory, but old. I just got new speakers, which I want to replace my old OEM one’s. Upon taking out the old one’s, I noticed that Nissan uses a black connector to connect the wires to the terminals on the speakers. The new speakers have terminals, but they are not set up in the same manner as the old one’s. Therefore, I can’t use the connectors. Can I just rip the wires out of this connector, or is there a better way? And which are which regarding positive and negative?
Okay, I managed to get the black connertor off, so the terninals are fine, but the speaker itself won’t fit into the orginal spot. Someone who has the same speakers Clarion Pro Audio 4x6’s, how did you fit your’s in? Help please.
Yes, as I stated earlier, I haven’t done anything audio-related before.
The yellowish bracket doesn’t fit the new speakers at all. I could try to cut out places where it doesn’t fit, but it will probably crack (the plastic looks old and brittle). How do they do it in a shop? Do they have pre-fabricated brackets that they use? Not only will they have to be cut to fit the deepness, but holes for the screws will also have to be made, and where the holes would go there isn’t much for the screws to grab onto there.
I do this everyday bud, and you have to cut the back out to fit the magnet
and notch the speaker bracket corners to fit in the alocated spot in the bracket.
