Hey guys, I have a little problem I need help with. Almost everytime I go over a little bump, I am getting a little squeek sound coming from my left front tire. This also happens at times when I brake. Apparently the pads and rotors are fine. Could it be wheel barings? Does anyone have any ideas?
That would most likely be your swaybars’ endlinks.
You could also try lubricating some of your front suspension components while someone is bouncing your car up and down for you (if doing that duplicates the squeaking noise), to help pinpoint and silence any moving parts that might be needing lubrication as well.
lowered? or over sized wheels? i have 18 inch rims on my altima, when i have 3 people in the back, every time i hit a bump, the rubber rubs and makes kind of a squeek noise. might be just that.
