Sr Help. (throttle, ABS Sensor)
Ok I have an ABS plug for the Passenger side ABS Sensor that I cannot find a home for. It doesnt seem like I have the right plugs that connect to this damn thing so maybe Im missing something. Anyone heard of anything that I have to do to make this sensor connect?
Also, I spent a lot of time trying to modify the Ka Throttle cable bracket to make it work on the Sr cause the Sr’s would leave the throttle open quite a bit cause it wasnt close enough to the throttle body. What did everyone do for this to make the throttle cable sit fine and stay closed when you want it to?
Thanks again.
I presume you are using a SR harness. I’d say that the SR harness didn’t have ABS, hence nothing to plug the sensor into… It’s not that tought to add, basically you need the right matching plug, and the right sheilded wire. Check the 240SX schematic in the FSM, the wires go to the dash plug, F1.
Throttle bracket - yep, I modify the KA throttle bracket too. Funny how all the info available for SR swaps never mentions things like this… Interesting thing to note is that the '89-90 throttle cable works with the stock SR bracket (it has more free length).
-Martin.
Alright great, thanks for the advise.
