I recently completed my SR swap into my CA chassis. And noticed that there isnt a plug in the SR harness that mates with my chassis ABS plug, so my questions is obviously which plug on the SR hareness would be for ABS?
On a second note, which color on the O2sensor plug is the signal to the ECU?
To have abs you need to remove all of your ABS wires from your KA harness and splice them into the SR one. It requires the removal of the SR harness again and ALOT of work.
The black wire on the harness is the signal[/quote]
O ok i didnt know it would work the same, so i guess my abs dies then as i do not have my CA harness anymore. If i pull the relay witth the light stay out, i pulled the “anti skid” fuse and that turn the light on. i just dont want to be tripping codes all the time.
