I have a 180sx, and the batery is smaller than normal, I have a charger for normal battery, but mie is dead. I was working on it, and left the hatch open and the lights killed the battery, there is still a little bit of life in it though.
So how shouldi do this, Would booster capables work or would i blow out the battery, Jump start it, or what about the charger, anyone know the voltage they take?
How low is it? I’ve heard if its as low as around 5volts some normal charges won’t even charge it for some reason. Thats what happened to one of my mini batteries earlier in the year…
BUMP START!!!
once shes runnin the alt will charge the battery…
get the car rollin like 4-10km/h with the clutch in and car in first then drop the clutch like your doing a burnout and she will start…
had a toast starter for 6 months with an old cavy… bump started all the time… just walk the car out of gear and run with it then jump in clutch in, slam in first and pop the clutch.,
your alt is ment to top the battery not charge it when its low so if you dont want to burn your alt out i would charge your battery, dont boost or bump start thats only good if your stranded
