k so ive been having this problem with my sr for like the last few weeks…
so awhile ago i donno what really made my car start being gay but it would stall out and not start and then bam suddenly it would start… so id did that for a few weeks and i was like wtf fuel pumps going maybe … then one day stop running all together cant get it to start…
i changed the fuel pump cause i thought might be the problem … cause thats kinda how it was acting before it died.So i was diving in to the problem deeper i found out that my ecu doesnt come on not spark and no fuel … so i was like grounding problem grounded the shit outta my engine nothing … then i was like fuse … checked them all nothing… relays all replaced(impoortant ones)… ecu maybe no not that… mybe my wiring went over it all made all ned\w connections and still nothing … the last thing i can even think of is maybe try to find a new harness and switch it all but thats a bitch i really dont know what to do i need insight
Same thing happened to me. Try to start, no fuel pump, no spark, no nothing.
I would double check your wiring. And buy a noide light see if you injectors are getting a singal at all.
For me it was my ECU. And then a couple days later my alternator went. It is acutally kind of common on SR’s, comes up on nissan forums a little bit. The alternator will start spiking and burn out the ECU.
