SR20 slave problem
so i blew my slave the other day
bought a new one from napa and put it in
been bleeding it for a day
and now im very sure theres no air in the line
and the pedal has quite a bit of pressure behind it
but not enough to push back out all the way
but if i push it to the floor and let go quickly (with my hand)
the spring catches and pushes it out with a loud thud
i dont know whats wrong or why i cant get it to push out all the way on its own everytime
Did you bench-bleed it?
Check your master cylinder too
master seems fine
and theres no air in the line
theres lots of pressure but it wont come all the way out
did u bypass the damper? master straight to slave ftw
What this guy said, easy mod too.
just pulled that out
do i just bend the hardline to the rubber line connected to the slave?
do i need tools to bend a hardline cuz i couldnt seem to do it by hand
bent the line straight to the slave
worked like a charm :smiley:
fuck that box
Told ya!
