when i turn the key it makes a click, not clicking but a single click everytime i turn the key, and the car wont start, is it the alternator, or could it be somthing else,
Battery is probally dead, get a boost…
try to spray a little wd40 on the starter connection to the battery or clean off the terminal … i had the same prob and my battery was still good.
hope that helps
corey
yeah, it’s prolly battery related, not enough amps getting to the starter.
the other things i’d check is the ground cable on the battery and starter as well as the positive lead to the starter motor from the battery.
This is a simple problem and nothing to worry about, won’t dent your pocket book to much.
if all u’re power is fine try push starting it, if that gets it started u know its u’re starter…
