For those with an STI, what is your voltage at during normal idle and around say 4k rpm?
The past couple days I noticed my STI getting a little sluggish on the start and then today I came back from picking up tires from Gus and when I went to start it back up to put her in my garage the battery was dead. Got it started again with my jumper pack and the running voltage is showing 13.7 at both idle and higher rpms. I’m thinking its just the battery (about 99% sure) but it seems odd that I’m not getting up over 14 while under load.
And that is why I’m 99% sure its the battery. Just wanted to check to see because the voltage seemed low to me for the higher rpms. It could also have just been the battery was still pretty dead. just took it off the trickle charger, but I’ll probably be replacing it tomorrow.
What do you guys recommend for a decent battery. For offroading I always used an optimum yellow top… but what about for these???
Hard to buy a ‘bad’ one unless you’re going as cheap as possible. Even with that said, the WalMart ones are fine. There are like two companies that make batteries, and then they just get marked by the seller
do not get a adv battery man there junkkkk , go and get a napa good one and it will last . your voltage is normall for a car with a good alt and low batt voltage . bettin after the new batt running volt will be 14 .
