Just curious what it should be. I heard 7 psi but I think im wrong.
i thought it was around 10-11 psi
7 Psi.
you are very wrong kent!
stock boost presure on 100% stock ca18det is 6-7 psi, u can crank out about 10 psi if u fuck with the actuator and vacum line arrangment!
stock boost presure on 100% stock ca18det is 6-7 psi, u can crank out about 10 psi if u fuck with the actuator and vacum line arrangment![/quote]
oops lol :oops:
And how exactly is this done???
buy a $10 ebay manual ball and spring boost controller
And how exactly is this done???[/quote]
hook vacume line directly to actuator and u can also bend the actuator a bit so it has moe tension on it!
