I am extremely impressed with this kit so far. It is the Turbo XS front mount kit. It comes with the intake, coolant bottle, front mount, bumper beam, charge pipe, t-bolt clamps, couplers, etc…
I am doing the basic things at first, so that I can actually fit the intercooler and trim the bumper when it gets warmer out. Today, I fit the shortram intake. It involves removing the factory air box, and removing the maf. The factory maf goes into an aluminum maf housing, and then attaches to the factory intake pipe. From here, you simply attach a 3" cone filter to the new maf housing, and its done! Without a brace, this would sag, and put stress on the intake pipe, but they thought of it, and included a nice brace. It attaches to the factory mounting point for the air box, and secures the bottom of the new short ram.
While I was over by the new short ram, I installed some weather striping that came with the kit. This rubber stripping goes into the hole cut in the engine bay, where the factory air box connects to the snorkus. This rubber stripping will later prevent the charge pipe from rubbing against the metal on the car. While I was in there today, I saw no reason why not to install this piece.
Next, I installed the new, smaller coolant overflow bottle. This was the easiest thing I did today. The old bottle just unclips, and then pulls out of the car. The new bottle attaches to one bolt hole, which is located next to the battery tray. You then simply run the hose into the new bottle, and its done! Very secure.
Next, I had to lower the factory fuel lines, and replace one of the shorter ones with a longer line. This was easy, but the instructions were slightly misleading. They said to reuse the factory clamps, but they did not fit over the new line without pinching it. I went to autozone and picked up some 14 - 16 mm fuel injection line clamps, and this worked perfect. After priming the fuel pump, I checked for leaks, and there were none! I am going to check it in another day to make sure that it does not start to leak.
So, this is a great start. When we get some warm weather, I will finish the project. This involves removing the top mount, and replacing one of the breather lines that was previously part of the TMIC. From there, its as simple as running charge pipe, mounting the intercooler, and TONS of trimming to make the front bumper look perfect. Thats going to be the toughest part.
I look forward to getting this all done, and seeing how it affects the car. I am doing all of the supporting mods now, to handle a larger turbo. I may run a meth kit on the stock turbo for a while, and see how much power I can make with the VF39. I shouldn’t have to worry about any cooling issues now, so I can see what it makes.
–mark
