Does anyone know the partnumber and or where i can find the stud’s that the rear subframe bolts on to, my front two bolts broke outta there welds and know the front of my subframe doesn’t bolt on tight. I went to dealership and they couldn’t find them on any diagrams and couldn’t find them on courtesy nissan’s site or my fsm either, i know a few people on this forum have had to replace these so someone here has to know the partnumber for these things.
they didn’t actually break, but the welds broke while i was tighening them and on top of that, i didn’t realzie and went all nuts while tightening and messed the threads on the stud up real bad, hence now i need a new stud.
If you’re referring to the studs that hold it to the bottom of your car, I believe there is no replacement, you just have to weld a new bolt on in that spot.
i don think dealers have replacement parts for that…
since it is not recommened by nissan to do so
u probly have to source out the stud else where
just find the thread size(could be 14x1.25, not sure, but thats the size for the one on the 02-06 altimas)
and probly get a higher grade bolt to replace it
