Hey guys and gals,
I first purchased my car in August of 2003. I fell victim to the infamous 3rd gear synchro failing. My clutch blew and I threw in a lower km 91 KA tranny and new clutch and was back on the road.
Ending up going sideways into a curb, my HICAS was out of whack and I was driving around with a spontaneous +/- 1 toe changing constantly.
I didn’t know 240sx and I presumed that this swaying of the rear end of the car normal until I went threw tires in a month. During this month my older bro also took my car out for a spin and put it sideways into a curb. Threw the rear alignment out even more.
So, in December I was driving my car after getting new rear control arms installed and all wheel alignment, having 3 different types of tires on my car, it started only working on 3 cylinders.
I popped the hood at idle and pulled the spark plug from cylinder 4 while the engine was running and there was no change, still running on 3 cylinders.
Pulled cylinder 3 plug and then the engine dropped down to two cylinders.
This made me think that the cyl 4 injector was out. I went to the auto parts store to purchase a new one at $186.12 and he recommended i take the injector out and turn the inition to see if fuel comes out.
In hindsight, I think he was under the impression I had top feed injectors. I took it out when the car was off and got a buddy to crank the engine. Needless to say, fuel sprayed everwhere.
I Plugged the injector back in for the time behind, but the next time I fired the engine I had white smoke pouring out of my exhaust.
I made it home and dumped the oil and drained well over 4L in from the oilpan. Somehow I was the victim of a blown headgasket.
Anyways, being a naive 18 yr old trying to fix his only mode of transportation (I live in the boons) I pulled the fuel rail from a 92 Altima (KA24DE, cost for all 4 injectors, $75) and stuck a ‘working’ injector in, but the headgasket was already blown.
I ended up taking the head off and sent it in to be machined (needed a few valves changed too)
I threw it back together with new NGK Iridium sparkplugs and the engine wouldn’t start (I have also not yet gapped the plugs). I think I set the timing out of whack when putting it back together.
I checked for spark, its there. Checked fuel pressure, there, compression, there. Last I checked there the harness going to the injectors was funtioning properly.
So I cranked the engine over many times by now. To my understanding the KA24DE is an Interference engine, meaning if my timing was out of whack I probably have destroyed my valves by now.
So my main question is.
Should I rip apart the engine again and reset the timing… possibly having to spend money on a valve change and new gaskets (approx $350 )
or should I grab a working KA engine and throw on my ‘lower km’ 91 tranny and new clutch?
To my knowledge, can’t I get a nice 95-97 KA24DE for $350 and have it work with my 92 ECU/harness, etc?
responses would be appreciated.
