i would like a T3 oil line made from braided hose instead of the stock oil line! it looks restrictive.
i am unsure of what size line and fitting to use!
could anyone point me in the direction of where to get these parts??
the turbo is off a 300zx!
Many places should have what you need. If you pull the line you should be able to match teh fittings. My T3 line is -4.
-4an ss line and a couple of adapter fittings is what you need. Go to mopac and talk to them and they will hook you up. Just fing out the thread pitch on the turbo and block side.
BOSCH HYDRALICS is the only one that i know of that carries metric pipe taper threads…
and yes as mentioned above run a -4an line…
