ah, enjoy. hope it works out for ya…i feel your pain though…first thing that happened when i re-did my setup this year is my MAF failed out, then i got a new one and my TPS failed, then i replaced that only to find out my WG diaphram is torn…and have yet to get my new shit on the car…maybe ill at least have one week of it working the way it should before it comes off the road ;^(
that does sound very rod-bearing-esque. when the rod bearing went in my old b17a, it would just do it when it was cold and under slight, no load throttle. it then got worse until it did it all the time. this vid is from when it was pretty bad, just before i pulled the engine:
one of the bearings was completely shot, almost paper thin and squeezed out around the rod. there was a pasty metallic stuff in the pan, but no actual shavings.
think what you want the kid that looked at it is extremly well knowledge tech. as you know derek 11 million thing can cause that noise. with spending 3 minutes total on the car really couldnt full diag it. i didnt read this full thread but dos did u mention it looked like u had a 8 ball of metal in ur oilfilter
