Completely flush your brake system with some ATE Super Blue.
Bring an air compressor and good air guage since you’ll be playing with tire pressures, especially on stock tires that may tend to roll over more on the sidewall.
bring a gas can if you plan on driving a lot, they only have 91 out there and when its super hot during the summer its not worth risking it under high boost… make sure the tires have a good amount of meat on them (dont leave your spare at home in case you chunk a tire) brake bleed, make sure your pads have plenty of material (Hawk HP+ or equivalent minimum as even those will be smoking within 5 laps), i flush my tranny prior to each race just for comfort, and finally tighten up all your intercooler clamps etc, bring extra clamps and/or vacuum hoses just in case you blow something off your turbo system.
oh big fyi: make sure you have accessible tow points, i melted my wastegate hose at TMP and then blew the turbo piping off on straight 2 and was stranded out there for 30min before limping the car off. I realized when i was out there that i had no front tow point since my FMIC was in the way…
remove your front rotor heat shields (they unbolt) unless you want brown calipers and boiled fluid.
I would change any of the fluids mentioned if they have not been changed in the last 15k.
how much experience do you have…
for somebody with little to no track time you’ll be fine 100% stock in all aspects…
for an intermediate you’ll need all the brakes you can afford.
for advanced you don’t need my advice
at my last dunnville day I ran hawk HPS with track tires and didn’t overheat them (but I do have ducts). 6 months earlier I would have been all over the brakes a bunch more and overheated them bad.
First track day…
I’m putting HP+ on the car probably the weekend before… and swapping to ATE super blue…
The car only has 29k on it…(with at least 3-4 trips to SC and back, stock tires made it to 15k im not overly abusive) but I’m doing the clutch right now so I figured i will do all the fluids also.
I’m hopping to find a cheap set of wheels to throw tires on… or i’m stuck with my Goodyear all-seasons…
and I will take any good advice I can thats why i made this thread… oh and is the ride still available you offered awhile back
All that stuff is way over rated.
Make sure you do the typical safety checks(including pad thickness).
Done.
It’s not like you are doing a 6 hour endurance race or some old bucket of bolts vintage race.
Unless you have completely ignored maintence up to this point.
Joe’sTypeS was having serious brake fadding issues on a new evo when we were at TMP, that’s not really safe if you can’t stop. All the Diff fluid, tranny fluid, blinker fluid changes are over doing it.
Wrong. Stock pads and fluid WILL NOT hold up to lapping if you’re at all aggressive. I’ve done it on two cars, a relatively light Fiero with carbomet pads that I never had an issue with autocrossing 12+ events a year, and a heavy GTO with very good sized stock brakes. Both of them would have almost no brakes after 5-8 laps and I’d have to come in early.
At a minimum you need a good fluid and a track day rated pad. Unless of course you’re going up there as a poser because track days are suddenly “cool” and plan to just coast around the course. If that’s the case stock will be more than fine, but people will be getting very sick of constantly waiting to get by you.
