hey all,
As some may know, im rebuilding a manual 92 240sx since last year. The time has come to put it all back together. Its now road worthy other then it wont move.
i need some help finding out whats wrong with the transmition? i removed the old one to replace the rear seal and when i put it back in, it wont shift gears with the engine on.
Problems:
- shifts gears with engine off
- engine on; neutral (little to no movement), Will not shift into any gears with out slamming it in with clutch deployed,
Mods:
-bings short shifter
-New rear seal
- changed the rear tail section housing ( couldnt remove the original drain plug)
What ive done to problem solve:
-removed transmition to see if gears were ok. everything worked.
- Topped up gear oil with 70w90
- blead the clutch
So please help me, want it on the road asap.
Thanks All!
