Alright well there is a lot of useful information out there on the internet. Unfortunately a lot of it is scattered all over the place. This is my attempt to try and bring everything to one place. I have separated them into categories to the best of my ability in the time i have heh which is not a lot. Well here it is the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info…
Electronics/ECU
[SIZE=2]ecu pinouts and diagrams[/SIZE]
REWIRING YOUR IGNITION COIL
Distributor Timing
Removing speed limiter on 93 KA24DET
DIY Ignition Mods for Better Spark
Sr20det Ecu Fault Codes
SR20DET ECU wiring diagram.
FAQ: KA ECU # Glossory
A long tutorial for tuning nissan’s ECUs
How-To: Chip Your ECU with Pictures (KA24E)
Desoldering tips
Battery Relocation
Engine/Engine Info
SETTING THE BASE TIMING ON THE DOHC PROPERLY
How to build a KA24DE
How to: S13 Oil pan removal
DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE
How-to: Build Your Own Oil Cooler
S13 Red Top Vs. S13 Black Top - The differences
DOHC Turbo For Dummies
240sx Engine Descriptions
240SX How To: Removing/Replacing your PS pump
DIY: ITB’s for your KA24DE
Basics of engine management
SR20DET Installation Guide
1993 240sx Capacities and Specifications
HOW-TO: Fix Your Timing Chain Rattle
KA24e to KA24de swap - Step-by-step.
240sx (S14) HotShot header install
Does my 240sx have a bad O2 sensor?
240sx knock sensor replacement
How to do a compression test on your engine
RB25DET into S13 Installation
Engine Knock (Detonation) Sensor Replacement (KA24DE)
Transmission
How To: Convert from A/T to M/T
How to Swap Your Auto Transmission for a 5-speed
Changing transmission fluid / oil on s13
How to install paddle shift on an automatic 240SX
240sx Clutch and Flywheel Swap
S14 auto -> manual with pics
Clutch Swap
Fuel/Nitrous
REWIRING YOUR WALBRO 255 FUEL PUMP ON S14’s
240sx: Installing a Walbro Fuel Pump
240sx: Replacing Your KA24DE Fuel Injectors
DIY: Installing an injector resistor box
Nitrous Oxide FAQ
Turbo
HOW TO NEVER OVERBOOST AGAIN
Bobby’s DIY turbo oil feed/return lines install
Turbo rebuild DIY
Turbocharging your automatic-trans car
Suspension/Differential/Brakes
Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential
The Definitive 300ZX Brake Swap!
Advanced Suspension Definitions
Rear differential swaps for the 240sx
Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion
Rexbo’s Guide To Brake Caliper Rebuilding
240sx curb weights
All you ever wanted to know about differentials
Upgrading to J30 Brakes
ABS Removal
Interior
Removing the S13 Door Panel Fabric
Low-budget seat modification for S13
Re-covering Your S13 Glove Box
DIY: Window regulator repair 5$
DIY: Dye That Ugly Carpet!!! W/pics
Water leaking into trunk (240sx fastback)
Camera Mount
Exterior
HOW TO: Repaint Headlight Housing (Black)
DIY: Replacing Your Rusted Hatch
240sx Conversions - An Introduction
Sleepy Eyes walkthru (VID)
240sx Vented Hood DIY
Rust removal, Fiberglassing, and Body Filler
DIY: Silvia Foglight Wiring
All-red S13 Taillights
Restoring your Nissan’s paint
240sx power antenna repair
Article: General car cleaning/detailing tips
Factory Service Manuals/Diagrams
Factory Service Manuals (FSMs)
Your home for factory service manuals
Parts Lists / Diagrams / Setting Sheets
HowStuffWorks Articles
How Manual Transmissions Work
How Differentials Work
How Turbochargers Work
What is the difference between a turbocharger and a supercharger on a car’s engine?
How Car Engines Work
How Clutches Work
How Car Computers Work
How Fuel Injection Systems Work
How Car Suspensions Work
How Anti-Lock Brakes Work
How Master Cylinders and Combination Valves Work
What does it mean when a car has dual overhead cams?
How Camshafts Work
