Alright, I did my Valve Cover Gasket along with ym timing belt. Now the car is making a very loud hissing noise. Almost like a vacuum leak. The car still drives great, but there seems to be oil leaking out the valve cover.
Does the gasket need to heat up and bond? Or did I do something wrong?
Bah, I rushed thru things and forgot a handful of things. My altenator tensioner, forgot to tighten the one bolt. The clamp for the PCV valve, forgot to put that on, so oil blew all over the back of my motor. And then my Valve Cover Gasket is still leaking somewhere?
