More ducati issues.
starts hard choke on, need a blip of the throttle to get it to fire, wait a few MINS to warm up, back off choke and it wants to stall, gotta hold a higher idle to keep it running, throttle input and it runs like crap with crappy throttle response. Keep in mind this is EFI. Trieed to ride it around the lot, and it stalls out at full engaugement of the clutch, no matter how long you slip it out to get rolling.
When I got it back together, the tank smelled like kero or something odd, not gas. I emptied it the best I could when it was stored, but a little was still sloshing around. I put new gas in and a week later as I was putting the rest of it together, the gas turned turned cloudy looking. I emptyied some last night and it looks like straight cloudy pee, like after you drink a few energy drinks. Smell if off a bit again too. Put a fuel pressure gauge on it, and only got 31 psi (suposed to be 3 bar or 43.5 psi).
Dumped the rest of the fuel and pulled the pump sock and filter, all in tank. Pulled the sock off the pump inlet, and a little bugger of rusty looking gunk was right there. about 1.5mm dia or so. not alot but still not good. Put air to the inlet and gently shot a bunch more crap out of the pump, again brown looking crap. not a ton, but a bit of crap came out. took the fuel filter off and turned it around and shot it out too, a TON of brown crap came out, looks like someone used brown spray paint on the wall I shot it on.
Put the pump back in, no filter, and got 35psi now. still not enough. Pump is probably bad. $280 for a new Ducati pump.
So I grabbed a Walbro 255 off the shelf and plumbed it in the tank, no filter yet. put it on the bike and put the T gauge by accident on the reutrn line (1am not paying attention). Key on, for a blip up to about 10psi, and instantly dropped to nothing while the pump runs. Pump primes, but sounds like its bogging down a bit. sounds a bit odd to me. Switch the T for the pressure gauge to the feed side. Key on, pump sounds the same, and the pressure pegs the gauge at 100+psi and doesnt move. Key off and the pressure instantly drops to 42psi (about what it should be for the FPR) and holds dead steady, like it should. Key on, I can see a faint flow of return fuel in the tank from the return outlet, def not 42 psi worth though. (I think this is my problem).
I start it anyway. Choke on, fires the instant I hit the button, no throttle at all needed. 10 sec into warm up, choke completely off and it hold idle like a champ. Instant throttle response, and cleanish (need a power commander for open pipes and pod filters instead of air box). You can crack the throttle as fast as you want and it wont want to die out. I didnt get to ride it, way too loud for 1:30am!
So, is the pump too big? I have heard of people running them on bikes for turbo setups and such, with base FPR 3-3.5 bar or so… so i doubt its too big. fuel lines feed and return are the same as cars I installed these pumps on in the past, so volume and flow I doubt are an issue to cause the back up of fuel and high pressure. Or with all the crap I blew out of the old pump and filter, maybe the FPR is gunked up and not flowing enough volume when it opens to control the pressure. what do you think?
