I came out of school today to find my car dead, it turns over and over, but wont fire, I think it is a fuel pump related issue, cause it feels like it has no gas, I went and put a gallon of gas in it and nothin changed, Any Ideas ?
Push it off a cliff.
Or grab a flashlight, crank it a bit, then pull a plug and look down in and see if it’s wet.
lol my beater saturn is doing the same thing
Thanks I’m gonna go with option 1, just kiddin I’m goning back to look at it, Ill try that thanks.
So was my friends accord, I dont remember how it happened or how it was fixed so I’m gonna hit him up.
can you hear the fuel pump prime when you turn the ignition from “off” to “on”? Not “start”. You should hear a whirring sound for about 2 seconds, if not, could be the fuel pump, or the fuel pump relay.
well I had someone listen for it and he said he didnt hear it so i assume its that, anybody ever buy a realy, Expensive ?
relay’s are very cheap, the pump will be a bit more
before you go buying things, verify that the fuel pump is indeed not getting power. You can also jump the relay terminals too.
IDK how to jump the realy teminals but I doubt the pump is bad when I parked it is was running great and I have been having electrical probs, and it is a 91 with the majority of parts being OEM so I dont doubt a realy, and I’ll be sure to check everything, Im goning to look at it at 3:30.
Locate and remove the fuel pump relay.
Using the relay, and the following diagram, locate the terminals 30 and 87 on the relay SOCKET
Using a paperclip or a piece of wire jump socket terminal 30 to socket terminal 87. If the fuel pump primes, it’s the relay.
Here is a diagram of what’s going on in the relay
[/U]
Terminal 86 is grounded, when +12v is applied to terminal 85, it switches the connection from 30->87a to 30->87.
However, don’t be surprised if the relay you remove does not have a terminal 87a. You can replace it with either a 5 pin or 4 pin relay. If it is going to be used under the hood, ensure that you use a waterproof relay.
For more information on relays:
http://www.teamrocs.com/technical/pages/relay_basics.htm
ROFL that you have to specify.
This should work, even with the ignition in the off position.
But try it “on” if it fails to prime when “off”, just to be sure…
haha, well… you never know…
click edit, the first [ in the /quote] tag is actually before the [/color] tag
Face it, you might as well have a mod delete the for sale thread for this car.
You can’t post all your “need help now” questions on the same forum as your “for sale” threads about the same car.
Back on topic… it needs 3 things to run. Air, fuel, and spark. Get all three of those, even in the wrong mixture, and it will at a minimum run poorly.
Air: Not much could have happened to make it completely stop running. Lets assume you have air.
Spark: It’s colder now, wires have much more resistance. Your battery is also putting out much less power than when it was 40 outside. Remove a plug, put it back in the wire, ground it on the block, and crank it. Does it spark?
Fuel: Water in the gas and a frozen line? Fuel pump/relay problem? Blown fuse? You said you added a gallon of gas. Was it so low that you might have run it dry? Fuel pumps, especially old ones in abused cars, don’t like running dry and having the pickup suck air or all the crap that is probably in the bottom of your tank.
well, a MAFs failure would be one thing, though it will still start (it defaults to a preset voltage), just not well.
spray some pyroil in the TB see if it will cough, that tells you its fuel related.
Exactly. It’s not running at all, so I’m assuming it’s not air.
The fact that it happened today, on the coldest day we’ve had in a long time, makes me want to bet on iced up fuel line. Depends if the pump is kicking on or not.
