Looks like my fuel pump crapped out on me.
Being a Honda guy, hondas have a main relay that controls fuel pump and ignition. Do Nissans have something similiar?
There is no fuel pump hum while its on ACC. The fuse is good under the hood.
I did notice when leaving work a nasty sound coming from the back of the car. I’m assuming it was the pump. I drove home, filled up gas and made it home with no issues.
So basically, other then the fuse, anything else control the pump?
              I didn’t notice that you have an SR, so I don’t know if what I say will help.  If not, sorry.  But I hope it may help you, or someone else, if someone else has a similar problem with a KA right now.
There is a relay under the hood, in the fuse box near the power steering fluid reservoir.  I forget which relay it is though.
I had some trouble of this sort in the winter.  I traced it to a bad ground, in the trunk.  I ran a new ground wire from where the wire meets the sending unit (sits on top of the gas tank), to the body where the metal was clean.  It ran fine for a few days, then the pump died (so I changed it).  I bought an Airtex pump and strainer for $200; it has a lifetime warranty!  Carquest sells them.
              I couldn’t find that relay by the power steering pump. But I did get it running. The main wire was loose abit. I jiggled, checked the connections and snugged everything. Purs like a fucking kitten.
Thanks man!
as stated check all wiring to the FSU for continuity- and all terminals at the FSU
check the relay for proper operation by removing it - applying 12v to the coil side and check the remaining terminals for  continuity- they  should  “open / close” as 12v is applied
my most recent experience resulted in finding a faulty ECU-no signal to the relay - switched with a spare ECU -problem resolved
Let us know what the problem turns out to be.
EDIT  (did not see your 9:19 reply before posting this -glad you found the problem)
