Water in intercooler, need ideas!
I would just go speed density tune if that were a feasible option for you. ditch the MAF
I could, but I’ll have to get a different ECU and that would probably run me about $1000-$1500.
I drove through some light rain and wet roads the other day and the car seems to be running okay. So maybe the sealant Adam put on the car is working. I only have a so much time to drive the car before winter, so I’ll just drive it as it is and switch over to the stock MAF configuration in the spring.
A hot-wire MAF will work in ambient or elevated pressure. But only if it is hot-wire, or the obscure GM “cold wire” MAF, which is a Coreolis effect based mass flow meter.
A flapper door, or paddle wheel MAF must be ambient.
Where you have spectacularly fucked up is the LOCATION of the MAF. A good rule of thumb is that you need 5 diameters of straight, smooth, pipe before and after the MAF. Screens will help, you should NEVER remove the screen from your maf, it will ruin it.
The reason for this is velocity pressure. Your MAF meters airflow from the center of your tube, and releases it toward the side. This requires that the pressure and velocity be equal everywhere in the MAF. But since your MAF is WAAY too close to the bends, more air will be flowing at the OD of the bend. This will cause your MAF to be VERY in-accurate. I have done extensive testing of the effects of up and downstream tubing on the calibration of Granetelli aftermarket MAFS. The MAF is EXTREMELY sensitive to this.
To comment on Tom’s comment, you can have a BOV, vented to atmosphere, as long is it is BEFORE the MAF, wherever the MAF may be.
So you could go:
MAF, turbo, RECIRCULATING BOV
OR
Turbo, BOV (atmo) , MAF
OP: I have seen your car at LV, talked to you, and you seemed extremely cool. I enjoyed the chat we had, and if you want I can help you out with the MAF.
Thanks for your input, I knew that the way I installed it was half-assed, only the output side of the MAF had straight piping, and only one side had the screen. I plan on installing the MAF the stock way (before the turbo) and recirculating the BOV. I also plan on getting rid of some of the intercooler piping couplers by getting new pipe welded to fit much better.
LV = Lebanon Valley? Because I haven’t had the car there yet. lol
Did you buy the car with the RB swap completed? I talked to somebody with a black RB 240, assumed it was you. How many can there be around???
I did the swap myself, only had the car almost 2 years now. I don’t know of anybody else besides ErnGotti (user on here) that has a RB. Hopefully there isn’t too many people with the swap around here, I’d like to be different lol
BTW my name is Steve
