water line removal
can anyone tell me how I can remove the coolant lines properly off the turbo? or should I remove it off from the engine?
any pointers?
… I’m taking it off a ca18et… so basically almost the same as a ca18det
ty
ed
pull the lines off the engine then remove the assembly
then tkae hte lines off the turbo once its out the car
x2
No other way to do it.
it seems that the lines are going to the back of the engine…
how does it mount? can I just pull (yank it ) out?
oh man, CA turbo lines are hell on earth. The line on the back is bolted on in like two spots (10mm bolts), and it goes from like, hard line to rubber line to hard line and back to rubber. You’ve got to feel around with your hand following the line.
Make sure you replace the rubber line once it’s out, it’s prone to cracking.
