SORRY ITS LONG BUT I NEED TO BE DESCRIPTIVE.
As most of the people who went to Shannonville know, my alternator died that night.
Replaced it with a KNOWN working alternator from Martino.
Works fine, put my sub back in, works fine, today I notice my cluster lights are dim but my headlights and horn aren’t cutting out and the highbeams work perfectly.
Car isn’t bogging, running perfectly otherwise.
I get to my apartment, I have the security key on my car keys so I take out my keys from the ignition, place the security key on the pad to open the UG door, and low and behold when I go to start the car it doesn’t start. Cranks, but no turnover. Just as I figured.
So I push it to the hill, bumpstart it, it starts asap, no problem (lol its a bumpstart…) and get to my parking spot. Again, nothing out of the ordinary except the no-starting and dim cluster lights.
Stop the car, turn it off, check the battery terminals (mine have been known to come off) but they’re snug as hell.
I look at my amp fuse, disconnect it, and go to start my car again.
It starts. But it struggles. And I mean like… a crank, sounds like its going to die off, then turns over like its nobody’s business. Stays on, again lights are fine, I flicker the highbeams a few times, and turn it off.
I did this twice. Once immediately after I turn it off, and once a little bit later to make sure it’s not just cause it had a slight charge left.
Both times it struggles the EXACT same way, in terms of how long it takes and how it sounds, but it turns over, unlike when I had my amp fuse connected.
This leads me to believe that it was the amp, no surprise, but the fact that it’s still struggling to turn over means theres something else.
I have a job interview tomorrow and don’t feel like bussing it.
Is my intuition correct? Any other ideas?
Thanks for reading my novel.
