apparently i’ve had a leak for a while…
so i spent the day workin on it
wow,that sucked,good fix!
nice fix!
the picture would have been cooler if you were in the hole… damn
sweet
did you really have that bad of a hole or did you cut it out and attemt to make a funny in your post…
at first look i though it was filled with water and grass now i c its a hole
so how long you think the duct tape and silicone is gonna hold???
there wasn’t a hole at all when i started…then i put my hand through it, then my wrench, then my foot…it kept crumbling the further into it i went (all that was under the pisser resivour) so i cut all the rotted metal out and that’s what was left
I see whre is that in the car? I thought it was the spare tire well…
spare tire sits above the pisser res. on a bracket
i wanted to make sure it would hold up so i bougth the thickest steel i could find at tractor supply…went through 4 cutting wheels cuttin the damn thing
wow thats nuts…lol
I May have some steel flat bars laying around if you need them from whan I was making seat brackets :dunno:
I will have to look…
only thing goin back there now is the battery box (hopefully tomorrow) kinda sux a bit where the car is sitting, combing the flat rear tires and the fact it’s sunk in the mud (notice the 2" from floor to ground) i can’t get under it enough to finish what i did today. that piece welded in there is pretty damn strong you can stand on it and it doesn’t lose it’s shape (not that i’d go jumping on it) but still.
well thats cool…
i’ve also decided i like that spray on bedliner stuff so much the engine bay is getting done next
quit parking in grass.
