what is wrong?
in the last week both of my fog lights have died… my gear shifter lights went out and my airbag light flashes and every so often my dash lights will dim a little… any inquires on whats wrong??
just in case ya didnt know i have a 02 sentra se-r
open your manual and look at the fuse/relay map. maybe it will give you some answers
i bet u need a new lighting switch
a lighting switch?
yeah. it could be. it’s the thing in the dash that turns your light’s on and off.
on a nissan, it’s probably on the turn signal stalk.
The airbag light coming is is probably an unrelated problem.
Could also be fuses. But intermitent problems are RARELY fuse related. Shorts are possible as well. They also suck to track down. GL.
its not on the turn signal control it has its own sepearte panel next to the wheel lol…
anyways … what do u guys reccomend i do… just look and hope or take it someplace?
any starting problems?
nope
check that switch. regardless of where it is.
