well anyways so i threaded one of the wheel studs… i really need my car to get to and from work. now would my best option be to just change the stud if possible or should i purchase a whole wheel hub? its for the front passenger side 4 lug. Its pretty bad when driving the wheel is pretty damn wobbily i guess u can say.
hammer the old stud out, get a new one (dealer sells them for sure). Hammer it in then tighten the lug nut with the wheel on to properly seat the stud
thank you for the quick reply.
If the wheel is wobbly when you have the other 3 lugs tight, there is more wrong. You may have to install 4 new ones. They are super cheap from UAP, so it would be worth it to do all 4. If the wheel has been wobbling there is going to be damage to more than just one stud.
Good luck man.
Theo
